:agree: I like 20 front/30 rear. Most folks run 18-20 front and 28-30 rear.Do a search of the posts. There are many of them out there already, and all kinds of answers and opinions.
It says 15 Front and 28 Rear +-2Pds.:agree: I like 20 front/30 rear. Most folks run 18-20 front and 28-30 rear.
Please note that 15 pounds is the minimum recommeded tire pressure marked on the front sidewalls. Marking a minimum pressure on a tire is unusual, and usually indicates a possible safety problem below that point. I would personally never run the -2 pounds in front that BRP recommends, for that reason. Twenty in the front will make a night and day difference in the cornering stability and firmness, no matter where the shock preload is set. The difference will amaze you!It says 15 Front and 28 Rear +-2Pds.
Is 20 of benefit in the front??
Thanks Scotty! I did a search and found out that I,ll be trying 20 -30 as many suggested. Should make them sweeping and sharper corners LESS mushy as you say!! Great Info here!!Please note that 15 pounds is the minimum recommeded tire pressure marked on the front sidewalls. Marking a minimum pressure on a tire is unusual, and usually indicates a possible safety problem below that point. I would personally never run the -2 pounds in front that BRP recommends, for that reason. Twenty in the front will make a night and day difference in the cornering stability and firmness, no matter where the shock preload is set. The difference will amaze you!
I've been running 20/30 and my rear tire is down to the wear bar in the center and almost there on the outsides after only 4000 miles.
Not necessarily in the case of the Spyder. The stock tire has quite a thin tread belt, and is prone to distortion at speed. Many of the higher speed riders seem to see more center wear than those of us that do less highway work and stay within the speed limit. Rider weight or carying a passenger also seems to have an effect. At 5K we show very even wear and at least half the tire life remaining, but we ride like the fuddy-duddies we are.center wear is an indication of too high air pressure
:agree:"Premature" rear tire wear has many factors attributed to it...throttle abuse, low air pressure, high air pressure, passenger/no passenger, etc. For the most part, how long you keep your tire will depend on no one else but you. My wife and I are always riding together and my first tire went 16,000 miles. I have 11,000 miles on my second OEM tire and will get over 20,000 out of it. Tire discussions are like gas octane discussions...a lot of personal inputs, all relative to the one doing the input. Let's just ride and enjoy instead of worry about what we, for the most part, cause because of our habits.
I run 17 front and 28 rear. Tire wear is pretty good at 29,000km (18,000 miles) I ride pretty hard in the corners but overall, gradual on the throttle. Based on the first 29K iit looks like I can expect near 50,000km (30,000miles) on the rear tire. The front tires are still like new.any insight to proven good tire pressures ? (I often ride with passanger)
This may be why mine is wearing so fast. I spend a lot of time at 70+.In my opinion...YES!
The front tires on the Spyder tend to roll under at the speeds our Spyder is capable of in corners. You can see it in demo videos and you can feel it when cornerning hard.
Even if you don't corner hard normally, you may, someday, come into a corner faster than you realized or intended and you'll appreciate the better traction afforded by 20psi in the front tires.
The Spyder holds the road better with 20lbs in the front. Some say it rides harder with a higher tire pressure but I think you have to be pretty sensitive to really notice a big difference in ride quality.
For me it's 20-Front and 28~30 rear.
NancysToy is right on about the thin tread belt and center distortion with speed on the stock tire. So, the faster you go and the more time you spend at high speed the more likely the stock tire will wear out in the middle.
The Toyo I'm running now has 4 tread belts (as opposed to the 2 tread belts on the stock tire). The tread area is noticably stiffer on the Toyo and is specifically designed not to distort at higher speeds.
Will this translate to more miles? Don't know yet. But it should.
