This one remains a puzzle to me. All other manufacturers follow the philosophy that the sidewall pressure is the maximum normal operating pressure when cold. The tires are expected to gain 4-8 pounds or more as they heat up. Kenda is the only one that has ever mentioned "never" to exceed this pressure. No tire I know of, nor any other product, lists an operating pressure or temperature that is close to the point of failure. There is always a large safety margin. Kenda's approach baffles me. Perhaps something was lost in the translation.. . . . according to Kenda, 30 psi is the max you should have in the tire - either front or rear, and hot or cold.
see this thread; http://www.spyderlovers.com/forums/showpost.php?p=133603&postcount=4
Tom
It's a head scratcher, all right, Scotty.
Bruce
I share your confusion, but I am used to being confused.
It is obvious that if the tire pressure exceeds 30 psi by 4 to 8 pounds, it will most likely not experience catastrophic failure - too many people are running at 30psi cold and I have not seen one post about exploding tires.
My totally uneducated and fact-less based guess is that the tire does have that margin of safety Scotty mentions and will not fail catastrophically if its PSI hovers above 30. But, above 30 PSI the tire (given its structure and class of materials) may deform and wear at a higher rate. In its design/engineering/manufacture/marketing this was probably a trade-off decision - not an unusual type of business decision for any product.
I really don't know if this is right, and if true, if it is a good or bad thing - and will probably never know. But, I will operate on this assumption and inflate my tires so they seldom go over 30 psi and hope I get more life out of them. That has called for some monitoring of tire pressures and riding conditions, events, style and preferences. My riding probably has a larger swing in temps and altitude than most. For the Summer, I got to 25psi (rear) 17psi (front) being my target. ( I like a firm ride ). With Fall and Winter coming, I will probably change that.
Like most mass consumer products, I am guessing as long as you stay in the specified range, you will be OK. Like I said, maybe by watching this, it will optimize my tire's life. Maybe not. The only things I know are;
So, I will watch it, maybe it will help. I also have a spare set of front wheels and tires. (yes, I hate those 3 points above enough to have spent the money on having spares ready-to-go)
- I hate the idea of replacing tires - especially the rear.
- I do not like riding on worn tires.
- I hate getting flats.
Tom
I'd kill for that on my Beemer. Usually only 5,000 to 6,000 on my RT, front and rear.Sounds like a reasonable hypothesis, Tom. So far, I am pretty happy with the Spyder's tire life,especially after years of changing motorcycle tires every 9,000 or 10,000 miles or so.
Bruce
My question, purely conjectural, is that if the 30 psi max is to keep the center from wearing faster at higher pressures, what keeps the outside from wearing faster if the pressure is lower than optimum? And what about loading...a heavy rider vs. a skinny one, or carrying a passenger? Not yanking your chain, just playing the devil's advocate with a little food for thought.![]()
The answer for me comes to us via Mad Magazine's Alfred E. Newman..."What, me worry?"The simple answer for my simple mind is, "keep it under 30 psi as best you can".
Tom
