Decided to replace my antenna with a shorter one... Bird hit my and split the fiber glass around the factory one. Replace it with this one... http://www.customdynamics.com/can_am_spyder_antenna.htm
Well I had heard they was some problems is getting the factory one unscrewed... Yep blue Loctite. So if you will take a soldering gun and put the tip on the brass 7mm nut for about 30 seconds or longer it will warm the Loctite up and it will unscrew. Do it quickly or the Loctite will re harden.. Just a old trick I learned about Loctite years ago..
