Throttle surging when in reverse backing up a slight incline ??
Spyder VaBeach
I have a 2010 RT with 220 miles on it. When in reverse backing up my driveway (on a slight incline) it seems to surge with a drastic loss of power. It does not happen as bad backing up on a level surface. Any ideas, or suggestions......
Reverse Gear
That is a Rev Limiter in reverse gear, a safety system on all Spyders. Does make it difficult backing up inclines.
With a little practice you might be able to overcome this just don't exceed the rev limiter usually it is around 2000 rpm plus or minus a couple of hundred.....:gaah:
Freebob...
Try this..!!
back up at idle with just a touch when needed. It is slow but the limiter is set low so it's the best way...:thumbup:
