With the cooler weather, I've noticed when I first start out its almost impossible to get a smooth clutch engagement using light throttle when the Spyder is cold. After a the bike warms up a couple minutes, clutch engagement is normal. What is happening is just as the clutch begins to engage, it'll slightly back off, then re-start to engage, back off, and start to re-engage, in a regular pulsing manner, much like what would happen if I was slight rocking the throttle back and forth just as the clutch was feathering. About 18k on the odometer, and less than 1k since the last oil change. I think if you were standing close by, you'd think I was not applying steady throttle as the clutch starts to engage.
It'll firmly engage with a little more aggressive twist of the throttle, but it's not a natural way to back out of the driveway, or pull away from a stop.
		 I crank the Spyder and let it idle a few seconds, then go into reverse and start backing out.  But, I need to "feather the throttle" to maintain a steady pace.  It has never bothered me,'cause to acts just like me!
