Thinking about TricLED lights
Spider-man
...but there are no installation instructions that I can find on their website. I don't want to take on more that I can handle, and even if people say "It's easy, you'll do fine", I want to read it for myself before I guy to see what is involved. Any ideas?
TricLEDs offers some of the most complete, and easy to understand instructions...
As well as the BEST LED lights for your Spyder! nojoke
What is that that you want to add to your bike? Perhaps someone in here can email you a .pdf file of the instructions... :dontknow:
FOR THE RECORD: I also like to get the instructions a bit early, so that I can plan things out...
Im looking at the RT stop and tail light package.
Is it just the 3rd and 4th brakelights?
Or is there more to it?
(I'm unfamiliar with their packages... :opps:)
I have all of the mechanical aptitude of a hamster, yet I was able to install these, (and many, many more!), on my RT Limited. :thumbup:
In fact I just ordered the running lights/Brakelights that fit into the rear of the saddlebags! :yes:
FOR THE RECORD: I have no financial interest in their Company... But my Missus would be PLENTY interested in what I've spent with them over the years...
My 2014 RT Limited currently has their:
Side Amber front fender LEDs
Rear red front fender LEDs
Mirror mounted turnsignal indicators
3rd & 4th Brakelight LEDs
Red Saddlebag LEDs
LED headlight bulbs
LED foglight bulbs
All installed by me: Mr "All-Thumbs, and no skill" :thumbup:
And that's just THIS bike! :roflblack:
I just installed these on my 2012 RT..If you pm me your email,I will scan them and email the instructions to you...Basically,remove Tupperware,unplug harness and the harness they supply to you plugs in series...
The easiest install and I think best Rear LED's for the money to start with is the RT Rear LED Saddlebag Run/Brake/Turn from TricLED.
I am going to make an install video, just been busy and have not gotten around to it.
If you can take your rear trim off and then remove 3 bolts to pull out your tail light you can do this. It is all plug and play.
yeah, that's the one. Thanks! I'll take a look.
If you contact Reggy at TricLED, I'm sure he'd email you a set of instructions to see what you're getting yourself into.
Bob, I have the running/turning/brake lights on the rear of the RT that fit into the rear of the saddlebags, and under the trunk lid, , and between the brake lights.
Here are some pictures of the LED'S that I have:
Rear LED lights+  turning signals 003.jpg these are on the right side/ turn/running/brake.
Here is a picture of the same lights on the left side: Rear LED lights+  turning signals 004.jpg These are on the left side/turn/running/brake. Also, they are bright, and they fit into the rear of the saddlebags.
I bought them from Spyderpops. Deanna
I've installed two sets of them... it's not too awful tough! :D
1. Remove the rear back panel off of the bike...
(Open the top trunk, ans sadlebags: four screws in the top trunk, and twon in each bag...)
Once that panel is off, you've got to pull the wiring harness, and plug their extension in... You'll want to bend a coat hanger into a "U-shaped" tool...Hooking that around behind where the plug is, makes the whole process about a thousand times easier! :D
Once you get past that; it's really straightforward!
(But when putting the back panel back on: make sure that the tab on it gets properly seated... nojoke
To install TricLED's 3rd and 4th brake light, you need to remove the part of the tupperware that covers the rear trunk. Instructions included with the lights is good. I'll add to Mr Denman's advice with one WORD OF CAUTION..maybe two.. when you remove that tupperware part, remember to tilt it a bit back and then lift STRAIGHT UP. Remember there are four tabs that extend into the black plastic. These four screws are what holds the tupperware in place. Do NOT break one of those tabs. It would be best if you had a helper to remove the plastic, someone to help lift and as it is lifted, press in lightly on the tabs so the metal clears the slot. Also remember to note that there are three tabs that need to be put back in the same place. Kinda easy to not do that. Again, ah helper would be good. Two tabs at the bottom that go over the upper lip of the black plastic and one that fits into a slot just below the trunk lock. If your trunk won't close, that's the reason. If you DO manage to break one of the tabs, not a disaster. There is a product, "Q Bond" (most likely found at an auto paint supply store), that will repair gray plastic and make it stronger than original. You only have 10 seconds to work as it is cyanacrilate OK crazy glue, hence the need for a third hand to hold the broken piece exactly in place. Build up powder layers around the break for strength. If you break a tab, you'll need three hands to repair it. But it's easy. Be careful where you position the wires that go behind the tupperware. And how you replace it. It is a bit fragile. Experience is a great teacher. Thanks for Reggie's support.
:opps: I qas afraid to mention my experience with removing the panel, once it is loose... :opps:
But your explanation is excellent! :clap: :2thumbs:
Thanks for the save! :thumbup:
(Oh! I'm just a "Bob". My Dad is in Florida... :D)
Thanks everyone for the help. Now, just because I can't go home with the first pretty face in the joint, has anyone tried the Spyderpops Brake/Run/Turn with Strobe? It seems like it may provide more bang for the buck for my needs.
http://spyderpops.com/rt-brt-rear-l...function-fits-all-rt-models-plug-n-play-easy/
I have the Spyderpops Rt-brt-rear- lighting kit - 4 sections brake/run/turning ( SPY184) on my 2014RTS-SE6. Here are some pictures:Rear LED lights+  turning signals 004.jpg left side turning Rear LED lights+  turning signals 003.jpg right side turning Rear LED lights+  turning signals 001.jpg under trunk lip/below trunk lock. These are bright They come with easy instructions to install. I have a 2014RTS-SE6 Deanna
The Spyderpops Brake/Run/Turn/Flash set is what i have on my F3 Limited and i love them, i also had them on my RTs and they looked good and were very dependable and less expensive than most other vendors, plus the support goes on way past the sale. I highly recommend SPYDERPOPS for LED lighting, the prices are better and the service is great.
When you get the Spyderpops set, it is complete.
Cruzr Joe
