The two blanking plugs. F3S
StreetBob
Sorry if it's been covered before. Please point me in the right direction if it has.
Either side of the ignition key are two blanking plugs. If you prise them up there are wired sockets attached....what are they for?
The left one is for the heated grips and the right one is for the fog lamps.
They are per-wired and set to go.
Agree...
:agree: making multiple wiring harnesses is expensive so many just make the one which which also allows you to add those features easily...:thumbup:
No fog here or the requirement for heated grips! So I just leave them as be...shame.
Use them for extra driving lights! I also used the third switch wires on my ST-S to run my USB port.
Driving lights (spot lights) out here can only be operated when high beam is on, Jim. That makes wiring to the right hand switch more difficult. If only we knew where the other end of those right hand blank wires terminate it would simplify things, but reading wiring diagrams is not one of my fortes.
Pete
Pete
In my case, the other end of the wires were right where the factory aux lights would plug in. Very convenient.
There were three wires terminated in a plug with a cap. Easy to spot. Only two wires were needed. Black is ground (earth), and then one wire worked with the low beams (dipped beam) and it cut off the aux lights when high beams selected. The other was on/off with the switch. So you can run them when you want.
lots of terminal connectins ?
so I am wondering about the harness , are the radio wires , and speaker wires in place ? and I wonder what could be put into the circuit too get radio and or what ever , for communications ? speakers would be easy enough ...
Yes, they are in place. I verified it on my bike.
