BLUEKNIGHT911
Sadly Passed Oct 2024 - RIP
:roflblack:....Really...This is going to be my big time winter project....and I want to thank Randy aka "ARTUFUN" for the inspiration to attempt this....After hanging with Him and Holley at Americade and S.I.T.A., and seeing what a fantastic job He did with a plain old "utility" trailer that He turned into an incredible "mini-motorhome" and Spyder hauler combo..and my Tent almost floating away (during the SITA flood rains) Iam going to follow in the footsteps of the Master and create my own.....To start I already have an aluminum 10 x 8 1/2 ft. sno-mobile trl....it weighs 475 lbs., My plan is build/attach a box on top of the trl. ( this would be permanent ) with a rear ramp and side door, some windows, and two sky-lites....the corner posts, top rails, door frame, & ramp frame wolud be made from heavy duty aluminum.. the walls would be galvanized formed heavy guage metal stds, with 2 inch ridgid foam board in between ( pink board). The roof would only slank one way for water run-off and the other side would have a roll-up awning attached to the wall above the side door.....inside I would have a " Murphy " style bed that would come down off the wall to use...The kitchen cabinets would be the ancient "metal" cheapo variety ( they are very very light-weight). A gas (house-hold type) cook-top...A 6 Gal. instant point of use hot water heater, a Mini-Frig, maybe a Mini-Freezer, a stainless steel sink (also lightweight). I plan to glue metal roofing to the sides and top....I have an antique lawn roller that weighs 750 lbs. and I plan to roll out the center of the roof panels, to make them flat, but not the two outside raised edges for water-proofing purposes......Anything anyone can think of to add or make this a better project I'm very open to suggestions......Annnnd I am estimating from my materials list that this thing will weigh approx. 1000 lbs To make this even more interesting if you want to place a guess on the final weight ( without the Spyder inside ) please do so. I will keep track of the Guess's and after I weigh it I'll let you all know....WISH ME LUCK.....MIKE
