I have to go and check the O.D. spacing for fit.
http://www.mcmaster.com/#cadinlnord/6436k53/=htet2g
This one is metric and the O.D. is 30MM or 1 3/16:
http://www.mcmaster.com/#cadinlnord/6063k32/=htf0yc
The metric one is actually 14mm I.D. and will probably be to small.
Both the EVO bar and my bars are actually 9/16 which is approx 14.3mm so I would go with the SAE and not the Metric collar.
Though I am not convinced that the double bend bars move all that much I've ordered a set of these in to see how they will work.
Will the OEM spacers (I have) fit my Evo sway bar? Unfortunately the Evo owner is not available to explain his product so I
just don,t know what to think. My Evo Worked Great for about 3,000 miles before I put the Elka,a on and now everything is Great.
Never had a problem with mine moving... had it on for around 40,000 miles.......
Just ordered metal bar clamps. I removed the frunk to have some paint work done and you can
see that the bar is off center and there is about a 1/4" gap between the bushing and stock
collar on one side.
RAYYOU,
I went a little overboard. Before I ordered the clamps I mentioned above, I had e-mailed someone from Australia about their clamps for their sway bar. Since I had asked him and he was nice enough to answer I also ordered his locks. So, now I'm double locked. But, what I noticed when I put the second set of locks on is that my Evoluzione sway bar is not symmetrical. There is more space between the lock and trunk on side than the other.
I just reread your post. Do you have the stock sway bar?
