stranded
daviszoo1
we have a 2015 rt limited with just over 20,000 miles. serviced according to the manual. about 8 miles from the dealership the bike would not move-grinding when either 1st or reverse. luckily the dealership was able to pick up the spyder. no word back on the problem...any one have any ideas? thanks
It sounds like your gear shift "actuator." When they disconnect, the bike will not go into gear. Coincidentally, this happened to me just this weekend. Mine happened somewhere between Wasilla and home--(20 miles). It will not go into reverse--but I still have my forward gears. Mine made it to my garage--so--so far, no tow bill.
Going to take it to the dealer this week. This happened to me one time before with my 2010. 30 minutes and about $50 later--I was good to go. Here's hoping the same for both of us. :yes::yes:
S-E 5 or the S-m 5
which cycle clutch or auto ? most likely auto ... ( It sounds like your gear shift "actuator." When they disconnect, the bike will not go into gear ) is this a vacuum actuator ? --------- are they now referred too as S-M 6 `s and so on ?
So what happend in this incident? How can you post something like this and not do an after repair report? Geeez....
Rick H.
Rick H.
Maybe still in the shop waiting for parts that are on back order. :banghead:
Could be 2 Dogs, but the diagnosis should have been done if that's the case. I just hate a story without an ending especially if it may help someone else out later on....
Rick H.
