Storing my spyder?
mowin
I may be storing my spyder in a friends barn. There is no power in the barn, and its too far to run a leed.
I thought I read somewhere that its not recommended storing w/o a battery.
Is this true?
I have it in one of those portable sheds for the summer, but Ive seen many of those collapse
durring the winter, and would be mad at myself if that happend.
My other option is to build a shed, which I can do,, if I get any spare time..lol
And I really dont like the idea of leaving it out all winter, even if its covered
There is a section in your manual regarding long-term storage. A battery tender is preferred, but removing the battery should be acceptable. Check with your tech to be sure. The manual does not prohibit it, it only says it should not be necessary (with a charger). Another option you might consider is heated storage at a motorcycle dealer. Many do bikes for as low as $200 a season, although a Spyder takes up more room and may cost you more. If you go the shed route, just be sure to keep the comprehensive insurance coverage during the winter.
my ins coverage is yr round. I dont have a manual, and have contacted BRP to try t get one, but no luck yet.
I tried to download one off BRP's website, but something is wrong and it wont download. tryed dissableing the spam and security
stuff, but no luck. If anyone has a extra manual for a 09 rs, ill take it...lol
The BRP storage procedure for periods over 4 months for an RS can be summarized as follows:
1. Stabilize the fuel and run the engine to distribute stabilizer.
2. Change engine oil and filter.
3. Spray fogging oil into each throttle body opening while cranking at Wide Open Throttle. Do not run engine.
4. Check coolant level.
5. Slow charge battery once a month at 2 amps. Battery removal not necessary.
6. Inflate tires to recommended pressures.
7. Check brake fluid level.
8. Clean and lubricate parking brake mechanism.
9. Lubricate parking brake cable.
10. Lubricate brake pedal pivot.
11. Lubricate front suspension bushings.
12. Clean vehicle.
13. Wax vehicle.
14. Cover with a permeable material.
Note that these are BRP's procedures, not mine. I take a slightly different approach. Our Spyders do get to stay on battery tenders, though. Many of the vintage bikes get the batteies removed, however.
Is this true?
Depending on how the barn is constructed I sure would think about rodent issues, especially with all the tupperware on the bike. With all the wiring and such it could be a nightmare next spring if something decides to nest in all that stuff.
:agree: A friend of mine had a snowmobile that was stored in a barn and found that mice had chewed into the seat and made a nice home in there.
Id be more that a little upset if that happeded....:yikes:
Thinkin im just gonna build a 12x16 shed.. Materials will run me around $1500.
Still no guarantee mice wont make a home in there, but Ill cover the thing with a 150 traps if i have to...lol
I prefer to have her on my side during the winter .. but my wife gives us no space in our living room
but in germany on the car-show (IAA) they offered this new "hanging-frame" for the wall - does anyone know the price and do I have to de-install the engine ???
