Roadster Renovations
Our 2014 RTS started having some squeaking going on when turning the bars when first starting out. Took it to the dealer and they diagnosed (incorrectly) that it had a bad DPS unit. They replaced it and I was very disappointed that the sound didn't go away after replacement. I started asking around and finally something someone said made sense. They explained that the DPS unit draws a great deal of power and at idle the alternator wasn't able to keep up. At higher RPM's it has no problem doing so. At idle, when this occurs the alternator has a slip clutch in it's drive system, and that is the noise. The slip clutch doing it's job. So, I decided to experiment a little....
