ST radio
The nice thing about the PAC SNI-35 converter is that it will attenuate the signal to allow use of earbuds or an auxiliary comm system, without damage. The volume can then be controlled from the handlebars at the multifunction control. It works real slick with my Starcom1 comm system, and should do a dandy job with earbuds, too. Using the RCA-to-3.5 mm cable mjw930 showed, then a matching 3.5 mm cable with a bulkhead connector, would allow you to just plug your earbuds into the dash or side panel.
Using earpods with half helmet
I have the Sena already but I want earbuds for when I ride with a half helmet. I can pair with my ipod and still control the tracks on the bars. I'll look into the other option. Thanks :doorag:[/QUOTE
Please let us know what you come up with Lamont and how well it works. :yes:
Do you have the Sena designed for half helmet use if not you could try these
http://www.senabluetooth.com/products/sph10h.php?tab_menu=overview
http://www.senabluetooth.com/products/sph10hfm.php?tab_menu=overview
Note the only difference between the 2 is one has FM Radio built in
