ST Limited Question
Suziespyder
Will the factory full cover fit over limited even with top case on?
And another question: how easy is it to remove top case and plate it sits on so I can use only on certain bike trips I take?
Nelson Rigg SPyder FULL Cover
Will the factory full cover fit over limited even with top case on? And another question: how easy is it to remove top case and plate it sits on so I can use only on certain bike trips I take?
I bought one of these and have used it for the past three years. I do not have a garage so it sees UV rays and rain all summer long. In winter, it goes on before one of those inexpensive nylon tarp things.
http://www.nelsonrigg.com/luggage/spyder/can-am-spyder-full-cover-detail.html
I have a 2014 ST Limited, but not with a top case. There is enough "slack", I feel, to accommodate your top case. Try it, and if it doesn't meet your needs, you could always return it.
Great product; excellent value. SO much less expensive than the BRP item!
This caught my eye
Living in a motorhome, we also have no garage. But boy what a ride. Our '13 STL is outside most all the time. We have gone through 2 covers in the 3-1/2 years we have had the bike. I would be interested in trying another cover as the ones we have been using are well over $100. This latest cover had the elastic give up after only 8 months. I would think the RT model is what I would want as we have the factory back rest. Thanks for your input.
Thanks Murrey
I have had my new Nelson Rigg cover for about a week now and it is 5 times better than the covers I have had before it and very little more money. I can tell that this cover would handle a back trunk without a problem.
Thanks for the recommendation. This is a good value. As said before, ours ST is out all the time also.
I have if you need...
I have a BRP full cover and a half cover I bought for my 2013ST LTD if you want them. Taking up space. Just pay shipping, prob around $30-40ish. BRP cover weighs a bit, built like a tank. :clap:
Steve
The Nelson-Rigg CAS-370 model seems to be able to fit over my 2014 ST-S if I am reading this correctly? The dealer told me that an RT cover should be able to take care of most Spyder models. Does that appear to be the story?
