ST high speed lean
tflatt
My wifes 2013 ST Limited leans to the right whenever she rides it. She said that the lean gets more pronounced the faster you go. I can not find anything wrong with the front end. Does anyone have an idea?
Yes, does it lean when you ride it? If so, take it to a dealer service department and find out why. First, check and see if it's level when it's parked. Then put your wife on it and check if it's level.
:agree: Check to see if the shocks not blown!! Jack up the front of the bike so the frame is level then look at the tires to see if they are the same distance off the floor,, then let it back down on the floor and see see what it looks like!! Check to see that both shocks are adjusted on the same level of adjustment. If its still leaning to one side take that shock off and look at it, make sure the springs not broke maybe the shocks lost it's charge push it down on the floor there should be some amount or resistance in both directions! Good luck, they don't last for ever!
