squeek, squeek
muonwhiz
Occasionally hearing some minor squeeks to brakes when applied as I first get out of driveway, but not heard after I have the bike at speed for street or highway. No change noticed in braking capability. Bike has about 3000 miles on it. More experienced ryders: annoyance to be ignored or warranty checkup time?
Common...
As already mentioned... UNFORTUNATELY this is common.
I've owned 3 Spyders (2-2008 RS's and 1-2012 RT-LTD) and they all squeak.
I would have hoped they would have it solved by now but NOT!!!!!:(
My best uneducated guess is that the pins that hold the pads in place get pretty gunked-up over time. Then the pads just can't move freely enough to get fully off of the rotors... :shocked:
Why not try dropping the rear caliper loose; pop the pins out and clean them up real well... See if that makes a difference.
Good Luck! :thumbup:
Spray away noise
Pads exposed to all kinds of elements. If it gets to bad, I just give a quick spray of brake cleaner, and all is good.
It's getting on into fall, maybe mice are building a winter home in your spyder Congrats, you're going to be a daddy!:yes::yes::ohyea::clap::roflblack:
