trobbins27
Hi All,
I tried emailing Harvey directly on this but haven't heard back from him so just thought I would see if anyone else has experienced this issue before.
I have installed the spyderpops Rear BRT LED kit recently for my 2015 F3-S. The strobe feature for the LEDs is behaving oddly... see description below:
The install went fairly well and the LEDs seemed to be working fine before buttoning everything back up. The lights are working as intended minus one odd behavior with the "strobe" feature. When using the foot brake with the bike engine off they work as intended with strobe. However, when turning the ignition key to the on position or if the bike engine is running the strobe feature no longer functions. The lights still work when hitting the brake pedal but they will not strobe like they are suppose to, the LEDs just remain solid the whole time.
Has anyone with this kit seen this behavior before and/or know how to fix it? I have also seen the below two things happen randomly on occasion:
1. hyperflash to one or both turn signals. I have tried the "re-program" method several times but the issue continues to surface at random.
2. Several times at random I have gotten "bad key" errors on the dash when attempting to start the bike. I have two ignition keys and this will occur at random for one or both of them. I don't know if this is related at all to the installation of the LED kit but this issue was never present before installing the LEDs.
If anyone has any input/ideas it is much appreciated!
