Looking at the oil resevoir placard reproduced on page 58 of the Spyder Operator's Guide PDF, it reads:
- Make sure engine is at operating temperature
- Roadster must be on a level surface
- Let engine running(sp) at idle for at least 30 seconds
- Stop engine & wipe the dipstick
- Dipstick must be screwed in completely before checking oil level
- Use SAI synthetic oil 5W40
The oil level verification procedure printed on page 78 of the PDF reads:
NOTICE: Make sure engine is at operating temperature.
1. Park the vehicle on a firm, level surface.
2. Start the engine and let it run at idle for at least 30 seconds.
3. Stop the engine.
4. Remove the left middle side panel.
5. Unscrew and remove oil dipstick.
6. Wipe the dipstick clean.
7. Reinstall and screw in the dipstick completely.
8. Again, unscrew and remove the dipstick.
9. Check the oil level on the dipstick. It should be near or equal to the upper mark.
At a glance, it appears to be essentially the same procedure. Does the placard on your Spyder read differently?
If you find a placard that disagrees with the operator's guide let me know and I'll include that with my query to BRP regarding front tire pressure.
Makes sense, except it's 21% oxygen, not 28%. I've seen tires go completely flat during long periods of storage, but I don't believe that has to do with the oxygen sneaking out, I think it's because the bead loses it's seal as the rubber shrinks.
Another benefit of pure Nitrogen is it's non-corrosive. The oxygen in the air we breathe causes all sorts of nasty harm to metalic objects...
Regards,
Mark
