danielnor123
Hello I have 2009 Can Am Spyder RSS SM5 manual transmission with a power commander and a two brothers exhaust on it. I took the spyder into the dealer today to get the codes read, and the dealer read the codes and stated to me that the codes all occurred and were not active. But, here are the codes and the main problem I have is that the spyder will say “hi temp” and then go into “limp home mode” while on the freeway (not while in idle), I can pull over for about 10 seconds and it will go back to normal operating temperature. Since I got the codes read I think the issue can be fixed, but does anyone have any ideas?
[TABLE="width: 714"]
[TR]
[TD]code[/TD]
[TD]state[/TD]
[TD]module[/TD]
[TD]count[/TD]
[TD]total time[/TD]
[TD]description[/TD]
[/TR]
[TR]
[TD] p0130[/TD]
[TD]occurred[/TD]
[TD]ECM[/TD]
[TD]1[/TD]
[TD]1070h55[/TD]
[TD]02 Sensor circuit no activity detected[/TD]
[/TR]
[TR]
[TD] p0170[/TD]
[TD]occurred[/TD]
[TD]ECM[/TD]
[TD]255[/TD]
[TD]1070h55[/TD]
[TD]Lambda regulation high limit[/TD]
[/TR]
[TR]
[TD] p0170[/TD]
[TD]occurred[/TD]
[TD]ECM[/TD]
[TD]3[/TD]
[TD]1070h55[/TD]
[TD]Lambda regulation: temporary adaptation +/- %[/TD]
[/TR]
[TR]
[TD] p0600[/TD]
[TD]occurred[/TD]
[TD]ECM[/TD]
[TD]11[/TD]
[TD]1070h55[/TD]
[TD]Communication fault with VCM, no response[/TD]
[/TR]
[TR]
[TD] p0600[/TD]
[TD]occurred[/TD]
[TD]ECM[/TD]
[TD]1[/TD]
[TD]1070h55[/TD]
[TD]Communication fault with Cluster, no response[/TD]
[/TR]
[TR]
[TD] p2545[/TD]
[TD]occurred[/TD]
[TD]ECM[/TD]
[TD]5[/TD]
[TD]1070h55[/TD]
[TD]VSS Failure[/TD]
[/TR]
[TR]
[TD] p2545[/TD]
[TD]occurred[/TD]
[TD]ECM[/TD]
[TD]5[/TD]
[TD]1070h55[/TD]
[TD]VSS light on[/TD]
[/TR]
[TR]
[TD] 0122[/TD]
[TD]occurred[/TD]
[TD]DPS[/TD]
[TD]N/A[/TD]
[TD][/TD]
[TD]N/A VCM Communication Fault[/TD]
[/TR]
[TR]
[TD] C0061[/TD]
[TD]occurred[/TD]
[TD]VCM[/TD]
[TD]1[/TD]
[TD][/TD]
[TD]N/A Lateral Acceleration Sensor Failure[/TD]
[/TR]
[/TABLE]
P1116 occurred ECM 123 1070h55 Engine Overheat
[TR]
[TD]code[/TD]
[TD]state[/TD]
[TD]module[/TD]
[TD]count[/TD]
[TD]total time[/TD]
[/TR]
[TR]
[TD] p0130[/TD]
[TD]occurred[/TD]
[TD]ECM[/TD]
[TD]1[/TD]
[TD]1070h55[/TD]
[/TR]
[TR]
[TD] p0170[/TD]
[TD]occurred[/TD]
[TD]ECM[/TD]
[TD]255[/TD]
[TD]1070h55[/TD]
[/TR]
[TR]
[TD] p0170[/TD]
[TD]occurred[/TD]
[TD]ECM[/TD]
[TD]3[/TD]
[TD]1070h55[/TD]
[/TR]
[TR]
[TD] p0600[/TD]
[TD]occurred[/TD]
[TD]ECM[/TD]
[TD]11[/TD]
[TD]1070h55[/TD]
[/TR]
[TR]
[TD] p0600[/TD]
[TD]occurred[/TD]
[TD]ECM[/TD]
[TD]1[/TD]
[TD]1070h55[/TD]
[/TR]
[TR]
[TD] p2545[/TD]
[TD]occurred[/TD]
[TD]ECM[/TD]
[TD]5[/TD]
[TD]1070h55[/TD]
[/TR]
[TR]
[TD] p2545[/TD]
[TD]occurred[/TD]
[TD]ECM[/TD]
[TD]5[/TD]
[TD]1070h55[/TD]
[/TR]
[TR]
[TD] 0122[/TD]
[TD]occurred[/TD]
[TD]DPS[/TD]
[TD]N/A[/TD]
[TD][/TD]
[/TR]
[TR]
[TD] C0061[/TD]
[TD]occurred[/TD]
[TD]VCM[/TD]
[TD]1[/TD]
[TD][/TD]
[/TR]
[/TABLE]
