danielnor123
I have a 2009 can am spyder with a power commander 5, two bros pipes on it and a kewl metal air filter, and when I ride I get up to about 60 mph and after I increase speed on the bike it will go into "hi temp", then finally it goes into "limp home mode", I pull over on the freeway turn off the bike for about 10 seconds and start the bike again and it is back to normal operating temperature.
I took the spyder to a mechanic we determined it was not the cooling system and not a blown head gasket.
So I purchased a new temperature sensor and a new oxygen sensor and replaced them, and no change.
So now I'm wondering if it is the power commander 5, I downloaded some maps but would like to either uninstall the power commander or tune the power commander.
I have no idea how to uninstall the power commander 5 or which map to use.
The maps I have downloaded are:
-power commander 5 (which shows the current setting on the power commander)
-stock exhaust/stock air filter
-two bros dual slip on stock air filter
-two bros single slip on green air filter
-two bros slip on green air filter
-two bros slip on stock air filter
-zero map
I watched a video on how to upload a map to the power commander 5 and it seems easy, but not sure which map to use.
OR
how do I disconnect the power commander 5 from the vehicle safely?
yesterday with the computer attached to the bike I started the bike with the power commander 5 and this is the reading I got:
RPM: 5026
% Throttle: 4
AFR: 0.00
Duty: 13%
Fuel: 10
Gear: 1
Speed: 0
-zero map
OR
RPM: 5026
% Throttle: 4
AFR: 0.00
Duty: 13%
Fuel: 10
Gear: 1
Speed: 0
