Spyder on ramps
Geez, Louise ...
Oh yes. Those are the ones I have and find them to be well suited - so far.
I use the ramps from Harbor Freight. I run the bike up on the ramps then jack the rear up with a floor jack and place a cinder block under the rear wheel. This works great for me!
am glad to hear what you guys use, leaning toward the Harbor Freight
any pics if a Spyder on the ramps?
I use 3 ramps and back up on them, I also drilled a hole into my driveway and inserted a bolt thru the tip of the back ramp so it could not be pulled forward when backing up as the front wheels just follow but the power to the rear wheel wants to pull the ramp forward.
Made up ramps used 3 ply 2by6 then cut 45 angle to drive up on. Same as you drilled holes in garage floor insert 3 bolts to keep from sliding . Lots of room for oil change on F3T.
My solution to ramps... plus there’s a 4500lb rolling air/hydraulic jack between the runways.
