M
MelloYelloSpyder
Guest
Good day all. Well I went over this past weekend and pulled the 13 Spyder STS-SM5 from storage. The battery had to be removed as the storage facility had no power in the units. I kept the battery on a Battery Maintainer for the past 3.5 months. When I started the bike up it was idling a little rough which I expected. I had an engine light show up at the bottom of the screen and flashed a couple of times. I shut the bike down, pulled the key and walked away. Came back and started it up and the light did not come back on. I let it idle for a couple of minutes and then rode about 5 miles to the doctors office. When I came out of the doctors office I fired the bike up and the whole screen went orange with an engine in the middle (the orange screen of death) just long enough for me to see it. I shut the bike down again and walked away with the key again. Came back and started it up and rode home about 6 miles. Shut the bike down while I was opening up the garage and getting ready to put up till winter is officially over. Fired the bike back up and no code or light and the idle was nice and smooth. I am wondering, as I have read somewhere, that if the battery is removed for more than an hour that you have to go through a start up procedure of starting the bike and allowing it to idle (no revving) for 15 minutes and then shut the bike off for at least 15 minutes for the computer to relearn its parameters. Is this the case or should I take it to the dealer. I did the button push to pull codes and there were no stored codes.
I was not able to store it in the garage before winter so I had no choice but to put it in storage and pull the battery. The battery is less than a year old and was obtained from the dealer.
