Spring Ryde
There are 3 motor mount bolts, 1 on each side, and 1 that goes straight through, roughly around where the rider's pegs mount, they mount on these. The long bolt and the right side bolt are replaced with longer bolts, most of the tupperware below the seat has to be removed to get to the bolts, but I already had it off anyway. I'm not familiar with the NMN mounts, I think they're like the Billet Bike Parts mounts that tie under the "fins" in front of rider's pegs. I should have it all back together tomorrow, if I can find my camera, I'll take some pics.
john
Another fuse box option:
Clicky: http://www.spyderlovers.com/forums/showpost.php?p=37702&postcount=1
Sounds like you need to try some of your own medicine-the mocha vodka valium latte.
can't help you on the fuse blocks. I think I am going with the eastern beaver pc-8 when it comes out next month. I imagine you already know about it. Any reason for going with kewlmetal brackets instead of the NMN? From what I read, the NMN set is for longer legs, which is what I need.
Am I wrong? :dontknow:
Okay, I need some input, from Corydon, shall we go to 145, then to Washington, or Loogootee, or Bloomington? This is beginning to look like a 2 or 3 day ryde. Any thoughts?
john
