spider 2013 rt
spiderweb54
Spider will not start, battery is good, nothing works on the dash complete blank,when I hook the charger to the battery everything comes on but won't start, take charger off everything goes blank, can somebody help me?
Looks like..!!
your battery is dead. Like :agree: Roger said. Don't know what caused it to go dead and it is a newer roadster but have it checked anyway..:thumbup:
Also check the ground wire to frame connection. There was a post not too long ago where he found the nut in the frame was loose.
good luck!
rember the batt,wires vibrate loose you must keep cheiking them if loose it wont charge i check mine ever 500 miles found them loose 3 times.and keep a batt.tender on at all times not riding.if you dont expect trouble.:yikes:im on my 56th bike thats how i know.:chat:
"Battery is good" :shocked:
What readings did you get off of it, when you hit it with a meter? :dontknow:
You have to start eliminating potential sources of the probles...
Start with the easiest ones first, and work your way into the deeper end of the pool/// :shocked:
Good Luck! :thumbup:
