Is it really necessary to change the spark plugs on the 1330cc engine at 28000miles is it required as per warranty requirements and if can someone direct me to a video showing how to on a 2014 RT Thanks
I did my first set at 34,000 miles and the old plugs looked good. I did not notice an improvement in performance or mileage with the new set. You do need to remove most of the upper tupper wear and the air box assembly so you can get to the coils. The plugs are directly under each coil. For the first time doing this I would plan on 5 to 6 hours.
My next set will be done at 40,000 miles, or in another 6,000 miles.
There is a heat sink material that needs to be applied to the spark plug threads. When I purchased the plugs from the dealer they put some in a baggie for me so I did not have to purchase any.
WAIT......what ??
Is that a "typo" ?
No typo
34,000 + 40,000 = 74,000
I have 68,000 on the RT so 74,000 - 68,000 = 6,000 miles to go.
A couple of those important details were missing before.
You said AT 40,000; that is quite different than in an ADDITIONAL 40,000.
And it just so happens that 34 plus 6 equals 40.
Do you really NOT see that it was confusing as originally stated ??
I did mine this weekend, here's a side by side comparison. Don't think I wasted my time changing them...
These had 50,000 kms - 30,000 mi 4 years old.
let me guess: you are using Ethanol (contaminated) gas....
however, still many miles left on that plug.... hope you put anti-seize on the new ones...
Dan P
SPYD3R
It should be heat transfer paste - not anti-seize.
sorry, i used the incorrect words....
i should have used heat paste, which is correct...
Dan P
SPYD3R
