fjray
For those that have installed the smooth spyder tensioner , What are you setting belt tension to before the installation and where are you setting the tensioner. I'm going to readjust in the morning with my pillion on board as recommended but there is a S#%t ton of leeway between old spec and new spec along with the preload setting. Right now I'm at approx 230 on the crikit with the tension set at 12lbs but I still have quite a bit of vibration at various speeds. TIA.
