eaglemrpaul
Just a heads up for those of you interested in maintaining your battery. I work at a store where we sell L&G tractors. In my opinion we sell way to many batteries. Part of the reason is that on small engines you have what amounts to a trickle charging system. Add to that that in Wisconsin these machine have seasonal use. I decided to do a test with an inexpensive smart charger on 10 exchanged batteries to see if I could bring them back to life. With 7 out of 10 the smart charger worked. They may not have been like new but they were usable once again.
From what I've read the concept is that as batteries create power, sulfate crystals attach to the plates. This can also happen during long periods where there is a lack of use. When that happens that portion of the plate is no longer available to produce electricity or take a charge from a standard charger. In theory the battery could show that it's fully charged while the reality is that only a portion of the battery has reached that point. A smart charger / desulfator sends pulses into the battery that can knock off or disintegrate those crystals bringing that part of the battery back to life.
Since acid filled batteries work on the same principal regardless of what they're attached to I connect my Battery Minder to the Spyder about once a month. Time will tell however I thought the $40.00 I spent on the smart charger was a relatively inexpensive attempt to extend the batteries life. Plus a battery failure in the middle of nowhere can really ruin the day.
