IGETAROUND
I was a little over due for fluid change; I have 17000 miles. Removed cover on reservoir, fluid and reservoir both pitch black. Removed fluid, cleaned reservoir with q-tips and refilled with fresh DOT 4 brake fluid. Then bled clutch master cylinder. All the fluid bled was normal clean looking brake fluid??? Where is all this black coloration coming from??? Would seem that if it were from deteriorated o-rings in clutch master cylinder that the fluid down stream from master cylinder to the slave cylinder on the side of the motor would be discolored also.
Clutch operates properly, doesn't slip and has always engaged at the very end of lever travel since purchased new in Feb 2015.
On other bikes there is a mild discoloration in the reservoir but this is also the same color down stream to the slave cylinder @ the motor. Why is the spyder different in this respect?? :dontknow::gaah:
