Whilst traveling back from AK, I suddenly got a brake failure warning "low fluid level."  Sure enough, the rearmost reservoir was down to almost empty (no air in the lines though!)  I kept it up by adding a small amount every other day until I got home.  Checking underneath I find that the boot where the actuator rod enters the master cylinder is leaking.  OK, so not the boot but the seal that is evidently under the boot.  Anyone experience this and if so, is it an 'easy' fix or a trip to the Spyder doctor?  Now that the F3 is sitting in my garage, it  doesn't seem to be leaking.  I suspect that using the brakes aggravates the situation.
Note updated signature: I'm now showing states/provinces visited by Spyder and not two wheels.
