bone crusher
Alignment Specialist
I bought the Belt Tensioner from Jim a little over a month ago and finally got around to installing it (a bit busy my way)...before doing so, I had a few nice conversations with him on the phone. I elicited the help of a HD buddy of mine as I didn't want to miss anything (he's a lot more mechanically inclined).
Anyway, the install on a GS is pretty straightforward...the bracket is well-made and the tensioner makes a lot of sense. It took us over an hour to install as my buddy and I are both OCD/neurotic and we had to make sure the belt was zeroed in to the center of the tensioner. There is always a bit of play so it's really not possible to get it 'perfect', but you can get it 'close enough.'
We had to cut 2 areas to get this on properly...one per Jim's instructions and another where the actual tensioner is in relation to the lower belt guard...meaning, when you put the belt guard back on, it's almost touching the tensioner...now, it's not touching, but it's darn close. Being things move around a bit when you ride, we decided to cut out the 'L' portion of the lower belt guard ONLY where it comes in close proximity to the tensioner. We used a razor and the carving is not noticeable from the outside of the bike. It does allow for more distance from the tensioner to the guard and we were happy with this.
I did not go out for a long ride after the install...only for a ride around the block a few times...however, the bike is a more smooth with gear shifts.
Note that there is a bit of a 'noise' from the tensioner on the belt, but it's actually cool...I like it...also, we checked the tension of the belt best when the bike was off the ground...left it around 11.5 lbs. of pressure...this seems to be fine.
The biggest problem with my bike is the RPM around the 4900-5500 range...below and above this range my bike is quite smooth...in this range and the bike has quite the harmonic vibration going...I'm hoping the tensioner will help in this range and I'll report back when I am able to ride it for a while.
So far, so good. This is a well-machined modification for your Spyder and I believe Can-Am/BRP should be adding this as standard equipment due to the long belt on our bikes. A tensioner makes sense.
Jim is a class act and I appreciate his product and his customer service. I have no proof of this, but I'd think the tensioner will also extend the life of the belt...
