This is a method of testing hypotheses about the mean of a small sample drawn (SL members, Spyder owners or not) from a normally distributed population (non SL members, Spyder owners or not) when the standard deviation is unknown.
Could it be that those calling for a bigger engine would also like more range and more MPG? :dontknow::roflblack:
If you want more range, they need a bigger fuel tank...the bigger engine is unlikely to provide what you want. A Goldwing engine in a Spyder would likely get the same kind of mileage. The largest portion of your horsepower goes to overcoming wind resistance at highway speeds. As speed increases, the power requirement increases a a function of the speed squared. I guess if you really wanted to increase the fuel mileage, you'd need a speed governor.The other option would be to make the Spyder more aerodynamic. That would require enclosing the suspension, eliminating the styled appearance in favor of a teardrop shaped lump, and closing the rider in more. If I wanted that, I'd buy a Prius. Cutting down the frontal cross section is not an option if you want to keep the third wheel. It is what it is folks. Wanting a bigger engine for torque, speed, smoothness, or reliability are valid desires...but wanting one for better mpg or range is just a dream. The laws of physics cannot be changed.
Unlikely. It takes a certain amount of horsepower to go a certain speed with a certain vehicle. Unless the extra gear dropped you back to a much more favorable spot on a sharp torque curve, you would see only minor changes due to differing engine efficiencies at different rpms. The Spyder has quite a wide, flat torque curve above 5,000 rpm, and horsepower drops off rapidly below that. It might not even be able to pull a higher gear at 70-80 mph. Adding an overdrive would be unlikely to accomplish much, IMO.Since power won't accomplish it, maybe an extra gear will (for us 70+mph drivers).
The pool is actually a very good indicator, non biased, fair and the projected time is 2015 (based on the BRP past releases rule "one year new model, next year cosmetic/color change").
Putting a big inch HD motor would be like dropping a hamster wheel into a Ferrari.
You guys have to admit.....there's no excuse for my car to get better mpg than my bike...:shocked:
Your post sounds like nothing can be done to get more range besides a bigger tank which isn't likely either. Oh well, sorry RT owners....180 miles it is. Glad I got the RS for just sport riding....LOL
See VW Tourag V6 vs. V8: better gas mileage for the V8, same car. nojokePut a Hemi in it...........:yes:
