Should I be worried about this Front sprocket alignment?
SpyderManTom
Just had the front sprocket recall done at my dealer, along with new rear tire on my 2018 RTL. Belt is touching OUTSIDE flange on front sprocket and INSIDE flange on rear sprocket. I drove it back there today, pointing out that the owners manual says that the belt should not touch EITHER flange on the front. They re-checked it, and said it was good. Got it home and it is still the same condition.
Should I be worried, or do I trust the dealer? (never used this dealer)
Trust the dealer? That's a tough nut.
Outside of the front and inside on the rear. Not much you can do other than space the pulley farther from the engine case.
Trust is earned. Hopefully you will be ok just maybe for peace of mind; document-date/times/mileages/conversations(with names)
By Jove! I think you've got it! I just glanced at the pictures for belt alignment. But there should be nothing between the flanged bolt and the pulley. Get them to put the washer on the correct (back) side and I'd say you'll be golden! That is if the install hasn't already done damage to the belt.
I apologize for not seeing this at first look. It's been a long week.
AND make sure they use the appropriate Locktite on the shaft splines per the recall documentation AND ALSO allow it to cure per the Loctite instructions! :lecturef_smilie:
No Loctite on the splines &/or No curing time will reduce if not completely negate any chance the recall sprocket has of doing the job properly and lasting! :rolleyes:
It is my experience that dealers are not allowing for the correct cure time in at least some cases. And you're right, that is a very important component to the fix.
Himm Learnt something.
How long is the recommended cure time?
Stand down found it.
I just wish I could find a schematic that shows the proper relationship of washer and pulley. Then I could show the guy at the dealership. (They are primarily a Harley dealer - based on what I saw while waiting, they only do a few Can Am service jobs amongst all the Harleys)
The washer is meant to go between the crankcase seal and the pulley (ie, on the MOTOR side of the pulley); then the pulley that's 'glued onto the shaft' with Locktite & cured for whatever the necessary time is that's detailed in the instructions for whichever spec Locktite they've used; then the last bit to go on is the bolt, WITHOUT a washer underneath it & between its head & the pulley.... :rolleyes:
I haven't looked tonight, but IIRC this is all fairly clearly laid out for any reasonably competent tech to follow in the recall instructions, so it shouldn't really be too hard for said 'reasonably competent tech' to get it right, but I guess that might be at least a part of the issue here - is the tech &/or any of the tech's supervisors reasonably competent!?! :dontknow:
Mind you, looking at that pic a little closer, I wonder if they've even put the pulley on the right way round - again, I haven't checked tonight, but IIRC the THICKER flange on the front pulley is the one that's meant to go IN, closest to the crankcase, and it's the one with the 'new' machined face that's meant to match up with the newly included washer that goes between the crankcase & the pulley.... and it looks awfully much like the thicker flange on the pulley in the pic is on the OUTSIDE! :shocked: Still, it is very hard to see clearly in the pic, especially on this small screen device I'm using atm.... :p So maybe this is all just conjecture & an inability to clearly see the pic?! :gaah:
Well, here’s the bulletin with installation instructions and pictures. NHTSA usually has this stuff - search by vehicle. The flanged bolt is correct. Your picture shows a bit extra thickness underneath, that could be the washer, or not. Perhaps you can get a better camera angle on it. And yes, the sprocket has an inside and an outside.
https://static.nhtsa.gov/odi/rcl/2022/RCRIT-22V352-1338.pdf
But, here’s what a brand new spyder sprocket looks like. They should be the same. It looks just as thick under the bolt as yours and it’s part of the sprocket - all one piece. Maybe take a breath.
Belt alignment
Belt alignment - even when you get this resolved, you may not get alignment on both front and back. My owners manual has that same admonition about the front sprocket flange, but the service manual is silent on the front sprocket. It is only concerned about the rear sprocket. I think the overall fleet experience has shown that you can’t get both. I couldn’t. The rear sprocket is priority.
Give us all a better picture of the face of your front sprocket so we can put this to bed!:2thumbs:
Spacer definitely goes on the inside of the current pulley 'Fix' install.
Well Ron I would say if I had to bet, the reasoning is in the tooling to set up a new pulley! Myself, I haven't had one of these new pulleys in my hand to compare with the old style, but maybe they had a few old pulleys that went into the heat treatment over again and repainted hoping to save money, you know how they like to do that sort of thing! And when they came up with the magic bullet they just kept on production! As far as the OP's first post, there isn't a great view of his whole face of that sprocket to really make a call on weather that shims in the right spot, thats why I asked for a better picture! But, Yes I totally agree with your thoughts on a wider sprocket, and a tighter back block assembly in the rear so those darn adjusting screws would not have so much room to slop around and give you the false sense that when you tighten the axle nut up your adjustment would stay where you put it, sort of like the adjusters on a two wheeler, both side hard to the frame, no slop!
Did you see snowbelts picture of his spyder it looks a lot like the picture your going by, and I would trust that man, that his is right. Sorry :dontknow:
Agree to disagree, Mr. Clouseau:lecturef_smilie:
