Shock Setting Advice
MMMII
What should I have the dealers set the shocks at on my ST-S? I'm about 230 lbs.
I saw the thread that suggested 5 for front setting but didn't know if that applied also to the 2013s.
Any insight is appreciated, thanks!
shocks
if it is anything like the previous models BRP has put out in the owners manual there is a chart by weight for the shocks to start with
There is no adjustment and the springs are very weak, I installed 2010 RT shocks and the difference in handling was amazing. I almost didn't do it as I thought they were now shorter, the stock shocks were compressed over 1" from just the weight of the spyder. The rear shocks have a progressive spring rate and feel plenty firm.
No adjustment on the front springs:yikes:
This is a concern for me also.
We don't all weigh the same.
Front end geometry can control roll and dive but more weight will roll and dive more:banghead::banghead:
The rear suspension actually carries most of the payload...
They've set the front-end up so that it's less sensitive to inputs such as weight and weight transfer.
It's simpler for them, and simpler for us. :thumbup:
