Shirt??? Base Layer??
spyderwing
What would be an effective shirt to use as a base layer under a mesh jacket to help versus the August heat and humidity??? Thank you. John
The obvious is Under Armour, but there are other similar fabrics out there that offer wicking properties for less money. You can find most anything at Walmart or Farm n Fleet, but pretty much always at any sporting goods store, for a bit more.
The cheapest and decent ones I have found from Cycle Gear, called either Heat Out or Chill Out I believe? They are pretty decent for function wise and are pretty cheap. Look for a sale, they are on sale quite often at Cycle Gear.
Sent from my SAMSUNG-SM-G920A using Tapatalk
You got it....
:agree: Works like a wet suit or swamp cooler. I have used them for years and they work great. You can get the shorts and tee or long sleeve and long pants depending on your model and air flow. Heat out and they also have some for the winter....:thumbup:
I wear a HEAT OUT shorts and shirt from Cycle Gear with a wet vest over that and a vented jacket (blow thru) for outer safety garment. This combination works very well on high heat days.
I`m going to go against the grain and recommend a good cotton t-shirt.
I've been living and riding in south central Alabama for 20 years now, and I think the first question should be, how much airflow you are getting over your body. If you ride a sporty bike with a small windscreen, or a naked bike, then the polyester shirts might work, as there is sufficient airflow to wick away moisture. But if you're riding a fully faired bike like a BMW RT or a Spyder RT, in my experience cotton works better. Cotton tends to absorb and hold perspiration better than the plastic shirts. That`s the key on a fully faired bike when relative humidity is the issue.
This year, we're having an unusually wet August and I've been re-validating the above. IMO, you can't beat a good, plush cotton t-shirt.
Not sure if these are available in the states but "Earth Sea Sky" Firstlayer Silk Weight. Excellent in the heat but also under thermals as a temp control layer.
Another vote for performance material. Nike, Under Armour, Russell, etc.
I used cotton for years and once I tried these I'll never go back. Cotton doesn't breathe well enough as compared to these. Plus, if traveling, they can be washed in a sink and pack very small, taking up less space in your luggage.
