Shifting problems from 1st to second. Not downshifting, No or very Low oil?
and a Quart and a half later...
Thanks for all the replies. Went to Walmart and picked up a quart of the best stuff they had: Mobil 1 Racing 4T 10W-40 Full Synthetic oil ($9.97). Before adding any oil, checked one last time with the Spyder at normal operating temperature on flat level ground and there was absolutely no sign of oil on the dipstick. Added half a quart of the oil, let the Spyder idle again for a few minutes, checked oil again, still no visible sign of oil. Added the remaining half a quart and repeated the same process, still no visible sign of oil on dipstick. Another trip to Walmart to purchase another two quarts of oil this time, just in case. Added another half quart and that finally did it. Oil appeared slightly below the full line. Finally!
I will ride it today and see if this resolves the shifting issues and will certainly monitor the oil immediately after each ride today to see if the readings are consistent.
....stay tuned for the results
WOW I would be checking the floor that is a lot of oil loss. I was down 1/3 qt in 1400mi.
Garage floor is clean as a whistle! No stains anywhere. My gut feeling, and the only logical explanation at this point in time, is it wasn't filled up properly at it's 600 mile service. Not to point any fingers, but the service was done at the same dealer that put Ron's sway bar on incorrectly, and then tried to charge me for the time it took them to remove the frunk (which you are all probably well aware doesn't need to be removed for a sway bar install). 5000 mile service will be at another dealer 4 sure and I will mention this low oil incident to them too and see what they think.
One foot out the door right now for another ride around town to check on the shifting and then another oil reading check! :clap:
Be careful with the use of Mobil1. It is marked API-SM, so it does not meet BRP oil specs. Some have used it with success, but if you have clutch problems, this oil coiuld be the culprit. For best results use an oil that meets the specs in your manual.
Shifting AOK.....
Just got back from a 40 minute ride in some the Sonoran Foothills back country, with a lot of twisties, small hills, and varying speed terrain. I am happy to report at this time that I did not have any further lurching from 1st gear to 2nd gear. Automatic downshifting now performs as it should without getting stuck in 2nd or 3rd at a stopped position, and overall shifting from 1st to 2nd gear was extremely smooth and quiet.
The Mobil1 oil I did use was an SAE 10W-40, but no, it wasn't MA2, only MA, so I will definitely not use that again. But I'm sure a quart and a half of BRP non-approved oil is better than a quart and a half of NO oil? Another 800 or so miles it will be in for it's 5000 mile service anyway, so it will get all new BRP approved oil at that time. After the ride an oil reading showed just slightly below full and before the ride at cold engine temperature the oil level was right at it was in Lamont's video. I just wish my oil panel was as easy to put on and take off as it was in Lamont's video. Mine takes quite a bit of force to go on/off (bet you somebody could make some good $$$ coming up with a new oil panel design that swings open and closed and can be latched closed)
But otherwise, I think the mission has been accomplished and this post has served it's purpose and hopefully will help others.
Thanks everybody! You guys rock :thumbup:
The Blue Recluse rides again!
:thumbup: Be glad it sticks when taking off. Mine did too before I took it in for service and tech must have lubed it. Many have lost them after oil changes. Make sure you tell the tech NOT to mess with it. I now use and extra Velcro strip to make sure mine does not pop off. I also saw a mod by an owner there that added a wire cable to the cover.
Happy to hear it's fixed.
I agree do not use anymore Mobil 1 since it is rated SM and on page 127 of your owners manual it states SM oil will damage your clutch.
:agree: SPECIFICATIONS
Please note that these are not BRP specs...they are the specs for a specific (not stated) Castrol oil. I believe in the use of JASO MA-2 oils, but BRP does not make any JASO specification at all. They do warn against the use of API-SM oils (prior to the 2014 RT). The BRP specs are in your Owners Guide. Threads with individual owners' preferences can be found by the dozens if you search here.
Whoa Nelly! That is WAY LOW!
You'll need to pay attention for possible slippage using the SM rated oil (as mentioned by others). While BRP does not spec out MA-2 rated oil, it is a very good idea to use one just so you keep that clutch happy.
Here's an old SpyderLovers post regarding the use of the Mobile 1 4T oil:
http://www.spyderlovers.com/forums/showthread.php?25988-Mobil-1-Racing-4T-10W-40-UPDATE/page2
Here are pictures of the oil that I purchased and used today (note the arrows):
Page 127 in my manual shows this:
So according to the recommendation in the manual, the oil must meet the requirements for API service SL, SJ, SH or SG.
Looking on the back of the Mobile 1 Racing 4T can, it clearly states it's a Jaso MA rating and "for the use in applications requiring API SH, SG, CF".
Guess this could be interpreted differently, but the use of the word "or" in the manual kind of says to me that it can used for applications requiring SL or SH or SG. And the back of the can shows SH and SG. Looks like the oil does meet the requirements based on that interpretation anyway. But then the "Notice" in the manual is where a contradiction comes into play. It says "do not use a motor oil meeting the API service SM". On the back of the Mobile 1 can it does show something about an "SM".
Not being an oil engineer, I don't have a clue what to make of it.....but i just thought I'd provide some more info on the Mobile 1 I used today and my interpretation of the recommendations. Either way, there are many other oils that can be used, and I'm not stuck to the Mobile 1 by any means. All I can say is my Spyder is shifting great now :yes:
It has been very good/helpful to hear the thoughts of others.
FYI, my 2011 has burned a full quart of BRP oil in 2200 miles. From reading here that's a little more than most but not alarming. Or should I worry about it?
Also when checking the oil after a good ride and fully up to temp, the level drops pretty fast after you shut down. First check is fine. Screw the stick in and out again and it has dropped 1/4. Do it again and its down 1/2 and so on. I have to say checking the oil on the spyder is sure screwy and can leave you wondering WTH is going on. That is until you realize that it works this way. I think this is a cause for many to probably over fill?
Bob
View attachment 80980 View attachment 80986
If you will look under the "JASO MA" on the label, you will see that it is also certified API-SM. That is prohibited according to BRP specs. Most oils list all the specs they meet, including the previous versions. Where use of a certain additive package or test protocol is prohibited, if that is listed on the label at all, the manufacturer intends for you to avoid it. Suit yourself, but I would stay away from Mobil1 just to be safe and to keep my warranty intact in case of clutch failure. JMHO
Bob
Off hand I would say there is something wrong here. With a dry sump system there is a check valve designed to prevent oil from re-entering the small oil sump in the engine. Otherwise there will be too much oil in the engine at start-up. The scavagening pump will fix this fairly quickly, but it isn't good at start-up.
I would say a quart at 2,200 miles is excessive. I used a little less than 1 quart at 6,400 miles. But I really don't know what an average amount would be.
I agree with Scotty here. It's really pretty simple.
Yes, BRP is ok with using an oil designed for applications requiring and SH, SG, or CF UNLNLESS it also contains additives which meet API-SM specs.
Some wet clutch machines are designed to handle the SM additives. Our Spyder is not.
So, how much SM rated oil does it take to get slippage? In my opinion, it's best not to find out. A new clutch is much more expensive than many oil changes.
