NancysToy
Motorbike Professor
Off hand I would say there is something wrong here. With a dry sump system there is a check valve designed to prevent oil from re-entering the small oil sump in the engine. Otherwise there will be too much oil in the engine at start-up. The scavenging pump will fix this fairly quickly, but it isn't good at start-up.
The usual cause of the level dropping quickly is dissipation of entrained bubbles from the return oil. Some oils retain the bubbles (foam) more readily than others. I find that the oil levels are the most stable if the initial reading is done from 1-3 minutes after the engine is shut off. Too soon and it reads a little high due to the foam (all dry sump engines foam the oil a bit, as the scavenging pump is not always fully immersed, so it can pump air as well as oil out of the sump). Read it after too long a wait and oil can cool and read low, or drain back to the sump, depending on the condition of the check valve and the position of the oil pump rotors. If your engine drains quickly or the tank drains dry, your oiling system should be examined. In that case your check may be bad or the oil pump may be scored or badly worn.
