Have been having shifting problems on our 2011 RT Ltd, SE5. It has been happening real intermittently, and not something that I can reproduce on will. Of course!! :sour: Took it to our dealer yesterday. Couldn't pull up any codes myself, but dealer hooked it up to BUDS today. They called today and said that there were two problems - one that was taken care of (they forgot to reconnect a sensor when they did work on the frunk last month and the ignition had been turned on before it was reconnected - that's been taken care of) The code they are calling BRP about tomorrow is P2806. (Gear position sensor angle - definer area vs. position not plausible)
Guess it would help if I would explain the shifting problem, eh? LOL!! Have had problems with shifting (with and without the RT 622 attached - yes, the trailer mode was on when attached) - would be in first gear, sometimes second and it would not up shift at all! Yes, my RPM's were in the proper range (4900-5100) (the dealer had called me earlier today to see if I knew that the spyder would not shift unless you were in the right RPM's - love being a woman....:cus
I downshifted once to see if it could then get it to shift up and it did. But then another time, it wouldn't downshift either. Another odd thing is that I would be in 1st or 2nd gear and without turning the throttle the RPMs would surge up and then go down. Haven't had either of these problems on our 2012. Any ideas??? Thanks!
Michele
Michele
