SpyderJerry
I just had a pecular problem with my 2013 rt se5. It would not upshift. I found after playing with it a bit that I had to center the lever after each shift. I took the control loose from the handle bar and saw that the spring loaded ball that returns shifer to center was stuck down. The spring was broke under it. To repair, I removed the shift lever. Removed the shaft rocker (use a magnet or make sure you cover the hole that the lever came out of as a steel ball will pop out) You will see the ball that is not fully extended(can be reverse or forward). Use a magnet and a very small screw driver or awl to pop the ball out, spring is under it. I had a spare control to get the spring out of. Reversed order for install. I did put some grease on the detent ball and spring for the rocker install. Depressed the ball and spring and install it by staying to the wider side of the swivel flange in order to miss it shooting back out of the lever hole. I'm sure that you could find a small spring at hardware store. I happened to have another spring in my parts stash and installed beck the spare control. Sure beats spending $350 and labor for a new control.
