Shift RPM/Clutch Lock up
RUOUTHERE
I know I've read at what RPM the clutch fully engages on the 998 engine, at what RPM does the 1330 fully engage? Looking to understand where I need to shift my new '14 Limited to prevent premature clutch wear.
Thanks!
If you put it in eco mode and watch the green arrow it will tell you when to shift for optimal performance ie. on both fuel economy and clutch wear... somewhere in another thread in here Lamont published the rpm shift points for eco mode on 2014 1330 engine
You don't need to worry about the clutch plates with the new transmission; it's a hydraulic; not centrifugal setup now... :2thumbs:
While reading my 2014 Operator Guide last night I found the clutch engages at 1100 rpm on the SE6.
Thanks all for the input.
