Anakrid
My 2012 RTS is unusable and my mechanic is stumped. It runs for about 10 minutes then loses power, spits a bit, small back fires, blubbers, stops, no response from throttle but will idle. Seems to be heat related except temp gauge shows lower then usual temps. Speedo pulses at idle. Will run again after 30 minute cool down. Not one fault showing anywhere. have spent terrible amount trying to fix. Help? Yes gas is good, wiring checked to some degree. Battery shows as good. Surely there is way to plug in and diagnose these machines----------was told that BRP techs were no help from dealer call in line which sounds goofy to me.
