Need some help, Security System Ignition Wire to Cut
So I've got my Scorpion I900 security system installed and have just one part left and need some help. The ignition disable option requires me to cut one of the following wires and put the ignition kill between the cut wire:
1. Positive lead wire on fuel pump.
2. Positive lead wire on fuel injection system.
3. Positive wire that goes to the ignition fuse in fuse box.
4. Ground wire from ignition module.
5. Positive wire from ignition module to ignition coil.
Which option would be the easiest one for me to find and cut into on the :spyder2: and where is it located?
This will enable me to disable the :spyder2: remotely if someone was to hold me up at gunpoint...hopefully that never happens.
Thanks in advance, Skeeter
