OverHillAndDale
I ordered the TricLED LED headlights and foglights because .... somewhere deep down inside I know that LEDs are better.
First, hats off to TricLED. These lights are great - very white, very bright. No problems installing the bulbs. Not so much for Can-Am - digging down to the headlights is a much more complicated procedure than I think it should be.
Here's the rub. The TricLED instructions do not address how to dig down to the foglights. The Spyder manual says "See your authorized Can-Am roadster dealer for the bulb replacement procedure." I went to www.cheapcycleparts.com to see an exploded diagram, and it lists the foglight parts as "Not available" and the diagram made me just a bit quezy.
So - what's the secret code to dig into the foglights? If I need to I'll just start removing bolts and clips until the part comes loose, but sometimes that approach leads to issues. For example, to get to the headlights you've got to remove a nut from a cable from inside the wheel wells on either side of the bike, far from intuitive. Is it safe and reasonable for me to just tear into the front, or can one of you provide some pointers?
