Second ram mount
greatrides
I needed a second ram mount for GPS because I don't us my phone as a GPS. The first mount is between the bars and the second I put up by the speedometer. I do t ever use the one on the right so it won't be in the way!! Heading to skyline drive and the blue ridge parkway next week and can't wait!!!!20160521_110542.jpg
Little checking..
JT's Machine Shop..a sponsor here on the home page has some products that will heip you with this....check it out...:thumbup:
Mount for 2013 Can Am Spyder ST-S
I am trying to put a mount for my iPhone 6S Plus on the handlebars similar to the way you have yours on the handlebars. Where did you find the mount to be able to attach the RAM mount arm and phone holder?
I just traded in my 2008 Roadstar, which had a stereo system, and already miss not having music and would rather not shell out the $700 right now for the Can Am radio adapter. I was thinking that mounting my phone and getting Bluetooth for my helmet would be a good option for now.
Thanks.
Thanks.
The x grip you can get anywhere and I mounted a 1 in ball to the plastic cap in the center of the bar. 20141223_174125.jpg
Took it for a ride
Went for a ride with the new mount...it has some movement to it but not bad. Next trip skyline drive/blue ridge parkway!!20160522_110654.jpg
attachment.php
Thanks. How did you mount the 1" ball to the middle of the bar? I actually have a life proof case mounting system that would attach directly to a 1" ball.
Drill a hole in the plastic cap placed a washer that would that would hit both sides of the bars on the inside of the bar with a bolt that runs through it. A nut on top of the plastic cap 2 more washers for spacers and the screwed the ball onto the bolt!! I hope that helps I know its a little crazy!!
Try this
attachment.php
I just installed mine 20 bucks no drilling works great. They also have great prices on helmets 30-40$ less than others and they are a site sponsor.
I have ordered something similar. I am hoping it works. Thanks.
the ram part itself looks the same, only issue I see is that the spacer that goes underneath May not be tall enough to keep the arm ( if you are even using one) off of the handle bars. Use the lower bolts they are flattest.
