Sea Doo parts - are the oil filters the same?
Geep
The nearest Spyder dealer is 2-1/2 hrs from me but there is a SeaDoo dealer 45 minutes away. Are the oil filters/O rings the same on both land and sea 1300 engines?
Sorry, I don't know the answer but am doubtful unless the Sea Doo uses the 1330 motor. Can't you order what you need online?
Sea-doo has No 1330 But you can use the Sea-doo 90 hp spark filter in the Ryker because its the same engine. Both are priced different?
The 1330 is a snowmobile engine. If the stock number is the same it will fit. Should be some snowmobile dealers around you.
One of the Sea-Doos uses the same filter but the can configuration is different and the O-rings look to be a quite a different group. Go mail order from Baja Ron!
I have 2 non spyder CanAm dealers close by, when I mention that I'm trying to cross reference a part to fit my spyder they suddenly forget how to operate a computer and reassure me that there is nothing they can do.
