While out riding yesterday, my SE5 started to loose drive momentum while in gear. This happened quickly. It seemed like the clutch was slipping badly. I was very close to home so I made it back carefully. Engine revs fine, transmission seems to shift well, but no forward or backward motion while in gear. I checked the following and all appeared fine:
Drive Belt
Rear sprocket
Torque on front drive sprocket appears ok? (put the SE5 in gear to check torque and bolt seemed tight but the sprocket continues to turn even when in gear?)
Any ideas on repair? Is this the dreaded front sprocket issue? Thanks in advance.
Drive Belt
Rear sprocket
