Scotty and yet another electrical question...
wyliec
Scotty,
I noticed in your album an auxiliary fuse block. Am I correct and you do not have a dedicated cover over it, other than the tupperware? I ask because I'm trying to mount a PC-8 and I want to mount it under the 'Y' just ahead of the seat; with the cover on it, it won't fit there. Wouldn't that piece of tupperware be enough protection?
Thanks
If I had been able to land a fusebox with a cover locally, I probably would have used one. I was too impatient to order one. I have added a plastic bolt cover for the hot post since my picture was taken. Still, this is an otherwise uncluttered area, and is covered in normal use by the removable cover under the trunk lid. It the location you mention, it is already tight, and I would be a bit more worried. I'd have to ponder that one a while, but I have concerns. Sorry I can't go out and stare at it a while to give you a better answer. Can't get around well enough yet after my surgery. You'll have to weigh the possibilities of anything contacting a hot wire with your particular unit. Depending on the way it is made, you may have no problems there, but I can't say for sure. Sorry I couldn't be of more help.
