Saw this lift on Spyder TV
Sweet . . . but if I had one, I think I'd enlarge the footprint on the floor . . . that is a lot of weight up in the air, with a high center of gravity . . . . sure would suck to have it tip over!
Very cool..!!
I think I saw them here before around $600.00 but needed the adaptors. Still do fine with the craftman I have at $89.00..:thumbup:
I used to have a rotary mid rise lift kinda like that bendpak. 6,000lb lift, single piston, movable rack points. It was nice for civics or similar sized/weight vehicles. It was movable via pump dolly and i got it for like $800. That being said, I refused to be around it with a car in the air because of how bad it would wobble when fully extended.
I really like that spyder lift, but i'm in agreement with a previous poster, that is just too small of a footprint for so much weight so high up.
I will say that my rotary lift wobble issue was significantly reduced after we bolted it into the floor. But then you remove your ability to move the rack around to maximize your shop space.
So i guess if this spyder lift model is boltable to the floor (maybe build ramps for the tires to clear the rack arms better?) then I would buy this.
Bought this lift earlier this summer, have not had time to assemble it, when I do I will post some pics and a review! Was thinking to put some sort of removable weights on the legs as a bit of added insurance!:thumbup:
