Madmartigan-glad to hear of your positive experience with the Elkas. Do you have plans to change out the front shocks as well?:thumbup::thumbup:
Your comment on pot holes tells me highspeed damping will be important to you. You pick up this adjustability with the stage 4 shock, so I would tell you its not just the adjustability in general but what specific needs do you gain. When you hit pot holes, they create highspeed wheel movement that can be felt as quite harsh impacts. The Spyder needs stiffer springs to keep the bike up, but stiff springs and no ability to blow off compression damping will likely amplify the pot hole impacts over the stock suspension. The highspeed damping will allow you to adjust high speed damping so you can blow off compression damping and only have the spring to contend with. The ride will feel much smoother if you have this function in your shock.
Most BMW bikes use Ohlins that's what I had on my RT 1100 loved them..
Wilbers are also quality shocks.
Martin on this board from Europe went with Wilbers and loves his. Do a search.
Good luck .
I have added Penske shocks to my 4 last bikes. What an incredible shock. I am not sure if these are made for the Spyder but might be worth looking to.
I get the impression that Madmartigan might not have been using the two up shock due to his "cheap rear shock" comment, Norm. But I may be wrong, of courseWhat Spyder are you running, Mad?
Pete
I have installed Ron's sway/stabiliser bar on the 2016 F3-L and have noticed a big improvement. I am wondering if installing the Elka stage 4 shocks (or something similar) would improve the handling/stability even more. Our country back roads are pretty potholed, and I put a fair load on the shocks. I am not interested in taking corners at blistering speeds, but simply looking at cornering etc stability. I would be very interested in getting opinions from those who "know".:thumbup:
Here is a link to a thread from several years ago. This spyderlover "clueless" went to a lot of investigative trouble to find the best shock for the $$ You can get the springs in what ever color you want. Pictures in link. Also read the thread below the picture where he posts all the advantages of their shock.
Unlike the Elkas, this shock does not raise your bike thus putting your headlights in cage drivers eyes.
This company Works Performance Shocks made shocks for the Disneyland monorail, the Space Shuttle, need I say more!
"click:http://www.spyderlovers.com/forums/...Installed!&highlight=works+performance+shocks
I have had mine on for over 5 years, and they still cut through the canyons like butter.
One last thing if you do end up with the Elkas shocks get the protector
- Protection of the shock's shaft from damage caused by flyings debris such as roost, rocks, sand and more that could lead to premature wear and/or oil leaks
since the elka shocks are installed upside down, Not like the OEM or Works shocks they need a protector.
Please let us know what you end up with.:thumbup:
Works Performance builds a good shock. When I was researching shocks for our 2014 RTS, I thought I learned they do not offer them for the newer Spyders. No doubt a call should be placed to find out.
Learning about Gil Vailancourt passing away last summer, I don't know what path Works Performance is following. Gil was the founder of Works Performance back in the mid 70's.
As for the orientation of the shocks, I agree, on these machines a shaft up position may be an advantage. The normal contention is less unsprung weight for better performance, but the Spyder is not heavily focused on performance suspension and the travel is short making it less of a concern. FWIW, Fox Shox are mounted shafts up / bodies down.
Can you give some info on Ron sway bar! Price and where to get info! The one from Lamonstor seams very expensive! Thanks
I'm confused TicketBait and PMK. (Not hard). Attached is an eBay listing with pics of the Elka Stage 4 Spyder F3 shocks. They do not look "shaft up" to me. Am I missing something? Or have they changed design for the the new F3.
Pete
http://www.ebay.com/itm/Elka-Stage-...-CAN-AM-Spyder-F3-F3-S-F3S-2015-/381519178379
Elkas are mounted shaft down. On the front shock installation, shaft down exposes the shaft to flying debris and more which can destroy the shafts over time. This was the reason someone else mentioned the need to run the guards.
On a rear shock installation, if debris from the rotating tire can be thrown at the shock shaft, the same results may happen over time.
No confusion, simply a common sense installation mounting position.
Thanks PMK....yeah, you can't buy Works shocks for later Spyder versions out here (or perhaps anywhere)..... we appear to be limited to Elkas or Wilbers. Based on what I'll have seen from Martins video, I'll try Wilbers first.
Pete
Pete
