BajaRon
Well-known member
A few customers have said they struggled with the front cylinder spark plug on the 900. It really isn't that difficult. But it is frustrating knowing that if that frame cross member were moved just slightly rearward. Or, just put a depression or flat spot above the coil would have done the trick. It is an unnecessary aggravation. But still, it's not all that bad. And, as mentioned, it goes back in easier than it came out. The rear 2 plugs are very easy. Do those first and it will give you a better idea of what is required with the front one.
