Running rich? Wheel noise?
Spyderman01
#1. I have 900 miles on my 09 Spyder and when driving from around 40mph to 60mph it sounds like its running rich and sputtering a little. Is that normal and is that the purge valve I have seen people write about?
#2. I also hear a high pitched whining noise between 45-60mph, sounds like the whine of the wheels and bearings turning, I am hoping that is normal?
1. BRP is to realease a second update to address this issue.
2. Have the dealer check the tension and position of the belt.
Mine does that too when im in 5th gear around 40-50mph. I think the Spyder likes to be reved a little bit, in 4th gear same speed, it does'nt act like that.
You should be doing 70+ in 5th gear. It is meant to ryde with high rpms. Don't go below 5000 rpms in a gear or you'll be totally lugging it.
I finallly found a 36mm socket at Advance Auto Parts ($20), its an axle nut socket, industrial quality and strength. I loosened up the allen wrench adjustment 1/4 turn at a time with test drives in between and after 1 1/2 turns, Voila', the whining is gone and she is a quiet as a purring kitten! One problem down, one to go..........
Mine was sputtering and stuff when I put a new pipe on it, but then I bought the juice box and doens't have that problem anymore now that's it's tuned right...I usually stick with 2nd 20-30mph, 3rd 30-40mph, 4th 40-50mph and 5th for over 50mph...but that's just how I do it, if I really wanna get on it, I drag raced my buddy and I was in 2nd getting ready to hit 3rd and looked down to see I was at 74mph...but it got up and went.....
